paulhiggs
Apr 15, 2021Aspirant
Overly restrictive DHCP server configuration in RBR850
ello
The DHCP server in firmware version 3.2.18.1_1.4.14 is overly restrictive in that it does not allow the pool of addresses to use the entire available subnet.
My RBR850 IP address is 192.168.2.1 with subnet mask 255.255.254.0, this allows terminal addresses from 192.168.2.1 through to 192.168.3.254.
The DHCP server funciton only allows addresses up to 192.168.2.254, and the first three bytes are not selectable.
My preference is to have the 192.168.2.x range for fixed addresses and 192.168.3.x for DHCP
1 Reply
> [...] subnet mask 255.255.254.0, [...]
I doubt that these consumer-grade routers were intended to work with
subnet masks narrower than "/24".> My preference is to have the 192.168.2.x range for fixed addresses and
> 192.168.3.x for DHCPChange your preference, or get a more serious router (or DHCP
server)? A DHCP pool like ".100" - ".199" should make recognition
pretty easy (without over-taxing the router).
