Wayvone's avatar
Wayvone
Parental Control Totally Failing
My new router does not filter ANYTHING on the internet for parental controls.  I have selected "Moderate" and then customized even more and if I type in very explicit nudity or other sites they freel...
  • DexterJB's avatar
    Jan 10, 2018
    Hi Wayvone,
    1. Are all your devices affected?
    2. Please make sure that the DNS values on the outer UI are set to the following:
    208.67.222.222 and 208.67.220.220
    3. Have you tried resetting the router?
    Dexter
    Community Team
