Farleigh
Jan 31, 2017Aspirant
Parental Controls and Google Chrome
Parental controls setup on Nighthawk router all working fine until now. It seems my Android tablets in Chrome aren't being controlled by the Parental controls or OpenDNS. I've checked all the sett...
- Feb 09, 2017Maybe some tweaking to my router will get parental controls working with IPv6 turner on.
https://www.opendns.com/about/innovations/ipv6/
doraemon
Feb 06, 2017Prodigy
How can it not let you change it? Consider your Nexus just like any other computers where you can manipulate its settings. Unless it's password protected and you do not have the key.
Feb 07, 2017Guru - Experienced User
Actually he might need to set a static address to over-ride the DHCP DNS settings. But it shouldn't be necessary.
Is the nexus possibly reaching the blocked sites over cellular?
