Netmound
Feb 22, 2016Aspirant
Parental Controls not working properly
Opendns settings not working. My n300 wireless router wnr2000 v3 is not blocking sites according to the opendns settings anymore. It was working for quite sometime then recently it stopped working...
- Mar 24, 2016
I wasable to come up with a solution. Thank you for your help. The only solution that I was able to come up with was to use Netgear genie app. Instead of using OpenDNS Netgear. I setup Genie to have parental control. Linkedin the OpenDNS account. Set the filtering. Enabled the filter using Genie. And bingo. it works.
ElaineM
Feb 25, 2016NETGEAR Employee Retired
Hello Netmound What's the DNS address you're getting? You can check this by accessing the admin page of the router then under WAN Setup.
Did you try to disable then re-enable parental control?
How about starting from the scratch?
Netmound
Feb 27, 2016Aspirant
Get Automatically from ISP
Yes i tried to disable and re-enable parental control to no effect.
I pushed the red restore factory reset button to no effect.
Any other suggestions?
