Netmound
Feb 22, 2016Aspirant
Parental Controls not working properly
Opendns settings not working. My n300 wireless router wnr2000 v3 is not blocking sites according to the opendns settings anymore. It was working for quite sometime then recently it stopped working...
- Mar 24, 2016
I wasable to come up with a solution. Thank you for your help. The only solution that I was able to come up with was to use Netgear genie app. Instead of using OpenDNS Netgear. I setup Genie to have parental control. Linkedin the OpenDNS account. Set the filtering. Enabled the filter using Genie. And bingo. it works.
Netmound
Feb 27, 2016Aspirant
Get Automatically from ISP
Yes i tried to disable and re-enable parental control to no effect.
I pushed the red restore factory reset button to no effect.
Any other suggestions?
ElaineM
Feb 29, 2016NETGEAR Employee Retired
How about if you check the DNS/Domain Name Server on this screen?
- NetmoundMar 02, 2016Aspirant
once i find this what should it be set to? What shouldnt it be set to? what should i be looking for here? and what is this screen called?
- ElaineMMar 03, 2016NETGEAR Employee Retired
The Domain Name Servers should be 208.67.222.222 and 208.67.220.220.
You'll be able to get that by accessing the admin page of the router.
See the steps here.
- NetmoundMar 07, 2016Aspirant
Well, I even tried this changing the DNS. This doesnt work nothing is blocked. I do not understand it worked a month ago then after I factory reset to update the email the filter no longer worked.
