Netmound
Feb 22, 2016Aspirant
Parental Controls not working properly
Opendns settings not working. My n300 wireless router wnr2000 v3 is not blocking sites according to the opendns settings anymore. It was working for quite sometime then recently it stopped working...
- Mar 24, 2016
I wasable to come up with a solution. Thank you for your help. The only solution that I was able to come up with was to use Netgear genie app. Instead of using OpenDNS Netgear. I setup Genie to have parental control. Linkedin the OpenDNS account. Set the filtering. Enabled the filter using Genie. And bingo. it works.
Netmound
Mar 07, 2016Aspirant
Well, I even tried this changing the DNS. This doesnt work nothing is blocked. I do not understand it worked a month ago then after I factory reset to update the email the filter no longer worked.
ElaineM
Mar 08, 2016NETGEAR Employee Retired
Netmound Try another factory reset. Use the 30-30-30 reset this time and then see if that will work.
1. With the unit powered on, press and hold the reset button on the back of unit for 30seconds.
2. Without releasing the reset button, unplug the unit and hold reset for another 30 seconds.
3. Power on the unit while STILL pushing the reset button and count for another 30 seconds before letting it go.
After the reset, reconfigure the router. By the way, how do you configure the LPC, are you using Genie or through the OpenDNS website directly?
- NetmoundMar 10, 2016Aspirant
Opendns. Dies it matter?
- ElaineMMar 10, 2016NETGEAR Employee Retired
It does not but just for isolation purposes.
- NetmoundMar 14, 2016Aspirant
The opendns didn't work, filter doesn't work
- NetmoundMar 24, 2016Aspirant
