Netmound
Feb 22, 2016Aspirant
Parental Controls not working properly
Opendns settings not working. My n300 wireless router wnr2000 v3 is not blocking sites according to the opendns settings anymore. It was working for quite sometime then recently it stopped working...
- Mar 24, 2016
I wasable to come up with a solution. Thank you for your help. The only solution that I was able to come up with was to use Netgear genie app. Instead of using OpenDNS Netgear. I setup Genie to have parental control. Linkedin the OpenDNS account. Set the filtering. Enabled the filter using Genie. And bingo. it works.
Netmound
Mar 10, 2016Aspirant
Opendns. Dies it matter?
ElaineM
Mar 10, 2016NETGEAR Employee Retired
It does not but just for isolation purposes.
- NetmoundMar 15, 2016Aspirant
The opendns didn't work, filter doesn't work
- NetmoundMar 24, 2016Aspirant
