DodgeThis
Oct 06, 2021Aspirant
Parental controls not working via desktop Genie
I was previously using Netgenie app on Windows PC to manage basic Parental Controls via the OpenDNS login. Was very happy with the service and ability to change filter levels for individual devices o...
michaelkenward
Oct 07, 2021Guru - Experienced User
DodgeThis wrote:
I was previously using Netgenie app on Windows PC to manage basic Parental Controls via the OpenDNS login. Was very happy with the service and ability to change filter levels for individual devices on the network.
Forget it. Free, or basic, Parental Controls are no more.
Netgear has announced that it is killing the free Live Parental Controls.
NOTICE: Live Parental Control Service based on Ope... - NETGEAR Communities
Instead, Netgear has a raft of paid for subscriptions. These may or may not work with your router.
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
Then there is this one:
and then:
How do I set up and install NETGEAR Smart Parental Controls? | Answer | NETGEAR Support
Forget about wasting your, and our, time by going to the "genie section". For a start, beyond reporting its death, that section has little to do with the desktop genie. (It is essentially for the mobile version.) Then there is the point that this issue has nothing to do with the genie itself but is a router side thing.
There's a slight chance that you might find more in the section for your hardware. That's probably here:
Nighthawk WiFi Routers
- DodgeThisOct 07, 2021AspirantThanks for all the help. Have niw gone with free (Basic package) of Circle.. Takes a little time to set up but actually I think it will be quite useful.
- michaelkenwardOct 07, 2021Guru - Experienced User
DodgeThis wrote:
Have niw gone with free (Basic package) of Circle..Thanks for that. I didn't know there was a free Circle. Makes sense to provide some sort of dumbed down starter version.
Now I know what to tell others who turn up here ion search of parental controls.
Thanks again. Certainly something appropriate for people who visit this section of the community.
