HelpMe3
Nov 07, 2019Tutor
Password change without access in my router
Hello community, i have the router Wireless-N 300 WNR2000 (i dont know the version) i bought it years ago,i havent the CD.. So,i dont remember the password i had and the URL in the browser where ...
- Nov 08, 2019
Look at the label on it. If there isn't a "V number", then it is V1.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
If you have forgotten the admin password, then only option may be a factory reset:
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
HelpMe3 wrote:
... sorry if my qiestion is a little silly.
There is no such thing as a silly question. Only silly answers.
Nov 07, 2019Guru - Experienced User
Can you log into the router via a hardwired connction? If so, all you need is the admin password to the gui.
If you've forgotten this info, then you'll be needing to reset the device back to factory and use the factory login info.
- HelpMe3Nov 08, 2019Tutor
how i can log with hardwire connection ? and where i can find the admin pass ? i havent any cd or paper..
about the return of the device i dont think this will help after so many years
