HelpMe3
Nov 07, 2019Tutor
Password change without access in my router
Hello community, i have the router Wireless-N 300 WNR2000 (i dont know the version) i bought it years ago,i havent the CD.. So,i dont remember the password i had and the URL in the browser where ...
- Nov 08, 2019
Look at the label on it. If there isn't a "V number", then it is V1.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
If you have forgotten the admin password, then only option may be a factory reset:
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
HelpMe3 wrote:
... sorry if my qiestion is a little silly.
There is no such thing as a silly question. Only silly answers.
michaelkenward
Nov 08, 2019Guru - Experienced User
HelpMe3
Nov 11, 2019Tutor
Mate problem solved,i restore the whole thing and i have access in everything...thnks a lot,i havent idea for this button i didnt see it before
