Bjb101
Nov 06, 2021Follower
Password not working to login to wifi extender network after connecting with wps on wn2000rptv2
I got this WiFi range extender (wn2000rptv2) used and it appears to be working as I did connect to the router with the wps instructions. The problem is that when trying to connect to the extender netw...
Nov 06, 2021Guru - Experienced User
Not all routers are properly coded for wps.
try factory resetting the extender and installing it using the installation assistant and not wps.
See if that works.
