robboyd
Nov 13, 2020Aspirant
Password reset or retrevial
I moved into a new, larger home and my wifi through out the house sucks. I found this old router when unpacking but cannot remember the password. I have searched on youtube but can't find the ACTUAL...
antinode
Nov 13, 2020Guru
> I have searched on youtube [...]
For _what_? Did you try anything simple, like, say, a simple Web
search for terms like, say, "netgear lost password"?
Here's another radical concept:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the Setup Manual (at least). Read. Look for
"Restoring the Default Password and Configuration Settings". It's not
complicated.
robboyd
Thank you.
Will be the first and last time I use the "community" as a resource, since smartass responses seem to be the go-to.
- antinodeNov 13, 2020Guru
> Thank you.
Glad to help. You did get the desired information, right?
> [...] smartass [...]
As we said when _I_ was a child: Better smart than dumb.
