daveplantz's avatar
daveplantz
Follower
Jan 08, 2017
PC cannot find 5Ghz router (2.4 is fine) ..phones & tablets can find 5Ghz
4 smart phones (2 Samsung...2 IPhones) and 2 IPads have no problem finding & connecting to both 5 & 2.4 Ghz routers....2 laptops can only find the 2.4 router.  Cannot find the 5Ghz to connect like the other devices
  • Hi daveplantz,
    Please make sure that the wireless adapters on the devices support the 5GHz band (dual band) since not all devices are capable of detecting the both frequency.
    Dexter
    Community Team
1 Reply
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi daveplantz,
    Dexter
    Community Team
