Finnpak
Sep 08, 2021Aspirant
PC doesn't see router
I had an older TP-LINK AC1750 Wi-Fi router which was working very well, but I wanted better coverage throughout the house. I had been able to connect with Wi-Fi with all devices on the older TP-LINK...
Sep 08, 2021Guru - Experienced User
What wireless card is installed in it and what driver is on it?
some wireless cards have struggled with the new AX spec.
Some you could fix by updating the driver directly from the manufacturer.
In more severe cases where you couldn't update the driver, users would do one of the following.
1. replace the wireless card
2. disable AX on their router
3. Use an old router as access point.
Finnpak
Thanks for replying so quickly. The WIFI interface is a Realtek RTL8188CE NIC. I am trying to download the driver from Realtek now.
- plemansSep 08, 2021Guru - Experienced User
there's also this thread that basically goes over the same.
MK62 Networks not seen by Lenovo with Realtek RTL8... - NETGEAR Communities
a driver issue from that wifi card.
