NeDaSolo
Nov 24, 2015Aspirant
PC is Unable to Connect to the R6300's WiFi Network
My PC is unable to connect to the R6300 WiFi router via the IP address, and the network is longer listed on any of my mobile devices' WiFi lists. I have already restarted (powered down) the R6300 rou...
- Dec 03, 2015Thankfully, I discovered that I must have pressed the WiFi off/on button and was unaware of it. Since then, I turned the WiFi back on and all is fine now. No need to factory reset this time. Thanks anyway for your response.
Retired_Member
Nov 25, 2015try a factory reset.... push reset util power led flashes
