PaulaP
Feb 12, 2017Aspirant
PC keeps switching from ethernet connection to wifi
I have a Netgear AC1750, model R6400. I have my home desktop PC hooked up by ethernet cable. For some reason, the router doesn't always recognized that it should connect through ethernet cable a...
- Feb 15, 2017
Hi PaulaP,
You can try temporarily disabling the wireless adapter on the computer so that the only active connection is the one for Ethernet. You can go to the Control Panel > Network and Sharing Center > Change Adapter Settings > Right click on the wireless adapter > Disable.
Dexter
Community Team
DexterJB
Feb 15, 2017NETGEAR Moderator
Hi PaulaP,
Dexter
Community Team
