Larry_G
Dec 22, 2020Tutor
PC Restart Required
I've used this external (USB) adapter without problems since purchased several years ago. In the last six months, however, I've started getting notifications that the PC needs a "restart" to comple...
- Dec 23, 2020
have you tried a different usb port? maybe the one its on is loosing power and thats whats making the computer think its re-installing the adapter.
Larry_G
Dec 30, 2020Tutor
Your suggestion appears to be right-on. The adapter was plugged into a 2-port hub with the second port empty. In the two days since I eliminated the hub, I have not seen the message/warning. Mucho Thanks.
Dec 31, 2020Guru - Experienced User
Glad you were able to get it resolved!
