cja59uk
Apr 25, 2021Aspirant
Pi-Hole using RBK352 — Orbi AX1800 WiFi 6 Dual-band Mesh System 2 pack
I am having trouble getting pi hole to work using Orbi Mesh. I followed an article which said that you can either just set up and use the pi-hole DNS server or also use DHCP on the pi-hole. If I do t...
cja59uk
Apr 29, 2021Aspirant
It seems that the only way to get this to work is to set the secondary DNS Address to: 8.8.8.8 which I think is Google.
