VickieMyers's avatar
Jul 28, 2021
Pin number
I have a nighthawk R6120 all devices connect except my laptop. It's asking for an 8 digit pin.  Where do I find this?
  • michaelkenward's avatar
    michaelkenward
    Jul 30, 2021
    Not dumb really. The problem starts with the way that the IT world talks about things like passwords.
    "security key", "passphrase", you name it. Different people use different words.
    That Netgear uses the password word for wifi, getting into the router, entering this place and various other things doesn't help.
    Here's a sentence from one of Netgear's manuals:
    "The security key is also referred to as the WiFi passphrase or WiFi password."
    Every reason to be confused.
