VickieMyers
Jul 28, 2021Tutor
Pin number
I have a nighthawk R6120 all devices connect except my laptop. It's asking for an 8 digit pin. Where do I find this?
- Jul 30, 2021
Not dumb really. The problem starts with the way that the IT world talks about things like passwords.
"security key", "passphrase", you name it. Different people use different words.
That Netgear uses the password word for wifi, getting into the router, entering this place and various other things doesn't help.
Here's a sentence from one of Netgear's manuals:
"The security key is also referred to as the WiFi passphrase or WiFi password."
Every reason to be confused.
VickieMyers
Jul 29, 2021Tutor
It's kinda dumb I guess on my part under the box that kept asking for the pin it said something about logging in with security key I entered the router pass word and that was it. Like I said it was so simple I was over thinking the whole thing I guess. But thanks again for your help
michaelkenward
Jul 30, 2021Guru - Experienced User
