JohannesM
Jun 23, 2021Follower
Pioneer as-wl300 wifi Versus a netgear wnce2001 WiFi Adapter
Hi, I would like to no if the WNCE2001 unit will connect up to a Pioneer AV Amp that has a LAN socket to connect to a WiFi or Network router. The router and the AV amp are not in the same room hence ...
Jun 23, 2021Guru - Experienced User
It *should* work if you already have that adapter.
I wouldn't buy it if you don't because its a pretty old device and there's better devices for the same/cheaper price if you're buying something.
(most wireless extenders have an ethernet port you could use)
