kestrel26
Jan 06, 2022Aspirant
PLC and Wi Fi
Is there a Netgear device which make directly PLC to Wi-Fi ? i.e a PLC emitter and a PLC receiver which is a Wi-Fi extender. If not, which devices may I use ? Thank you. Kestrel26
- Jan 07, 2022
PLC means Power Line Communication or Power Line Carrier.
But thanks to PatrycjaG who gave me the answer in the french section.
Kestrel26
michaelkenward
Jan 07, 2022Guru - Experienced User
Is that the same as Powerline Ethernet?
Powerline Networking - NETGEAR Communities
Powerline Networking | Powerline Ethernet | NETGEAR
Always helps to avoid initials that mean many things.
Care to post a link?
kestrel26
Jan 07, 2022Aspirant
Hi,
The device indicated by Patrycja is PLW1000 and it corresponds to what I wanted.
I agree to avoid initials but the references of the devices are also initials and it's difficult to understand what they mean just on a glance.
So I asked a question on the forum and i got and answer, a good answer.
Thanks for your help and your tips, I'll take care next time. Have a good year.
Kestrel26
- michaelkenwardJan 08, 2022Guru - Experienced User
You are not wrong there.
The device indicated by Patrycja is PLW1000 and it corresponds to what I wanted.Netgear makes several Powerline plugs that incorporate a wifi access point (AP). But my experience is that AP plugs are not the most capable devices around.
In my case I use regular (non AP) plugs to connect a more powerful AP – an Orbi router in AP mode – to the router.
