dotelvis
Jun 30, 2021Aspirant
PLEASE HELP
Why does my router update then tell me it has FAILED? Then it reads 403 error; page not available. ROUTER MODEL: WNR2000v5 Thanks for any help you can give me; otherwise, Netgear will charge me ...
olympos1625
Jun 30, 2021NETGEAR Employee Retired
Hi tddougla,
Good day!
Welcome to NETGEAR Community!
Thank you for reaching out. May we know what are the LED lights on the router( color and behavior)? Do you still see the wifi signal of the router? Please DM us the serial number of the router.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
olympos1625
Hi dotelvis,
Good day!
Thank you for getting back to us. Those LEDs are Power, Internet and WiFi. What are the colors of the LEDs? Please check ths link https://www.downloads.netgear.com/files/GDC/WNR2000V5/WNR2000v5_UM_20Nov2014.pdf
Please wired a computer using ethernet cable then check if you can go online or get an IP address from the router.
Oliver
Community Team
- dotelvisJul 01, 2021Aspirant
As previously stated, the lights are NEON in color.
My computer has Ethernet from it to the router.
- michaelkenwardJul 01, 2021Guru - Experienced User
Not a colour I have even come across.
Red, white, green and amber are the colours that Netgear uses. They can also be flashing or steady.
Neon is a technology. Neon lights can come in a rainbow of colours.
Where I live we call this 'greenish' color neon. :)
Where I live, we call this color Neon........but it is greenish!
- olympos1625Jul 01, 2021NETGEAR Employee Retired
Hi dotelvis,
Thank you for the clarification. Since you have green internet LED it means that you should be able to go online. Do you have internet access? You said that the " router update then tell me it has FAILED?" Did you mean that you are in the process of updating the router and it went successful but somehow telling you it failed or you cannot access a website? Does it affect all your devices connected to the router? What is the current firmware version of your router?
Note: Please try to reset the router.
Oliver
Community Team
Thank you Oliver for your response.
I have Internet access with all my gadgets; no problem.
Yes, It downloads the firmware then tells me it FAILED!
My last version is V1.0.0.74 and I was trying to get the latest one V1.0.0.76 which fails.
Before I pay $89.90 I will purchase a NEW router. I am a Novice swould you suggest what kind of router would work for me?
Thank you!
DOT
The best way to update firmware is to do it manually. The automated process can't cope with anything out of the ordinary. It can also damage your device if anything falls over in the [rocess. (The Netgear team isn't going to admit to that.)
This is the best option:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
I know I have said that before, but no harm in repeating the usual advice. It works for most people.
Don't do that. This place is free. Lots of (mostly) helpful volunteers.
Yes Oliver, I have rebooted the router! :)
Hi dotelvis,
Just for clarification, did you follow these steps?
To manually upgrade your router’s firmware:
- Connect your computer to your router with an Ethernet cable.
- Visit NETGEAR Support.
- Enter your router’s Model Number or Product Name.
- Click Downloads.
- Select a firmware version and click Download.
- Unzip the file if needed.
- Enter routerlogin.net into a web browser.
A login page displays
- Enter the router admin user name and password.
The default user name is admin. The password is the one you specified the first time you logged in. The user name and password are case-sensitive.
- Select ADVANCED > Administration or Settings > Administration.
- Select Firmware Update or Router Update.
The label varies by router.
- Click Choose File or Browse, then locate and select the firmware file that ends in .img or .chk.
- Click the Upload button.
Oliver
Community Team
ISSUE RESOLVED! Thanks everyone for your comments!
DELL had me power off and power on my Router then the upgrade process worked perfect! I should always remember to
turn off/on as that usually works with everything! Hooray!
