dotelvis
Jun 30, 2021Aspirant
PLEASE HELP
Why does my router update then tell me it has FAILED? Then it reads 403 error; page not available. ROUTER MODEL: WNR2000v5 Thanks for any help you can give me; otherwise, Netgear will charge me ...
michaelkenward
Jul 01, 2021Guru - Experienced User
Hard to tell without knowing what you are doing and where it goes wrong.
The best way to update firmware is manually.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
dotelvis wrote:
...otherwise, Netgear will charge me $89.90 to help me!
Your router dates back to 2014. Netgear provides free support for the first 90 days after purchase.
This place is free.
- dotelvisJul 01, 2021Aspirant
I have tried to download manually but I get an error message!!
