dotelvis
Jun 30, 2021Aspirant
PLEASE HELP
Why does my router update then tell me it has FAILED? Then it reads 403 error; page not available. ROUTER MODEL: WNR2000v5 Thanks for any help you can give me; otherwise, Netgear will charge me ...
dotelvis
Jul 01, 2021Aspirant
Thank you Oliver for your response.
I have Internet access with all my gadgets; no problem.
Yes, It downloads the firmware then tells me it FAILED!
My last version is V1.0.0.74 and I was trying to get the latest one V1.0.0.76 which fails.
Before I pay $89.90 I will purchase a NEW router. I am a Novice swould you suggest what kind of router would work for me?
Thank you!
DOT
michaelkenward
Jul 01, 2021Guru - Experienced User
The best way to update firmware is to do it manually. The automated process can't cope with anything out of the ordinary. It can also damage your device if anything falls over in the [rocess. (The Netgear team isn't going to admit to that.)
This is the best option:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
I know I have said that before, but no harm in repeating the usual advice. It works for most people.
Don't do that. This place is free. Lots of (mostly) helpful volunteers.
