dotelvis
Jun 30, 2021Aspirant
PLEASE HELP
Why does my router update then tell me it has FAILED? Then it reads 403 error; page not available. ROUTER MODEL: WNR2000v5 Thanks for any help you can give me; otherwise, Netgear will charge me ...
olympos1625
Jul 01, 2021NETGEAR Employee Retired
Hi dotelvis,
Just for clarification, did you follow these steps?
To manually upgrade your router’s firmware:
- Connect your computer to your router with an Ethernet cable.
- Visit NETGEAR Support.
- Enter your router’s Model Number or Product Name.
- Click Downloads.
- Select a firmware version and click Download.
- Unzip the file if needed.
- Enter routerlogin.net into a web browser.
A login page displays
- Enter the router admin user name and password.
The default user name is admin. The password is the one you specified the first time you logged in. The user name and password are case-sensitive.
- Select ADVANCED > Administration or Settings > Administration.
- Select Firmware Update or Router Update.
The label varies by router.
- Click Choose File or Browse, then locate and select the firmware file that ends in .img or .chk.
- Click the Upload button.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
olympos1625
Hi dotelvis,
That's good to hear. We're glad that you're happy with your NETGEAR device! NETGEAR Team.
Have a good day!
Oliver
Community Team
