kbguay123
Apr 23, 2021Aspirant
PLW1000v2 firmware
I have a netgear PLW1000v2 & the powerline that comes with it. i am trying to uodate the firmware becasue i have not done it since i bought it in 2018. no where in the user manual does it give direct...
kbguay123
I already reset it and it did not fix the issue I am having. But, thank you for your reply.
antinode
Apr 23, 2021Guru
> I already reset it [...]
"it"? What about the other one? You do have two Powerline gizmos,
right?
> [...] and it did not fix the issue I am having. [...]
A settings reset is not a magical panacea. "pretend that they're
new" meant to follow the set-up instructions as if they were new. It
did not mean that the gizmos would magically configure themselves.
With my weak psychic powers, I still can't see what you did, or what
happened when you did it.
