grahamfa
May 19, 2018Aspirant
Poor range and poor speed
I just bought this router thinking that it would provide faster speed and better coverage in my 2000 sq ft (one level) house, but this is the worst wireless router I have ever had When I connect dir...
- May 20, 2018
grahamfa wrote:
HI,
1) I'm assuming it's V1 since there is no v2 next to the model name.
Good assumption. It is usually the only way to tell.
grahamfa wrote:
2) Modem is TP-Link TC-7620 cable modem DOCSIS 3.0
Not a modem router that can cause local conflicts.
grahamfa wrote:
3) Clients - I tested with Windows laptop, ipad, iphone, and android
The killer. These things are capable of better speeds than you see.
grahamfa wrote:
4) Router Firmware Version - V1.0.2.98 - I did check for the latest firmware version and the one shown is the latestThese things rarely arrive with the latest firmware, which suggests that you may have updated it yourself. In which case, did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware. And wifi seems to be prone to these post-flash issues.The range thing is something else. The WNDR4300 doesn't claim to be a long range device. Are you connecting at 2.4 GHz or 5 GHz. The latter is faster but has shorter range. Paradoxically, you may get better speed using 2.4 GHz when you are not near the router.
Having said all that, if there is a way to return the device at no cost to you and replace it with something more capable, and probably more expensive, that is what I would do. Your call.
michaelkenward
May 20, 2018Guru - Experienced User
Is it really an WNDR4300? That's a pretty basic box. (Is it the original v1 or the newer v2?) Note the lack of antennae that come on flashier Nighthawk kit. But they cost a heck of a lot more.
grahamfa wrote:
When I connect directly to the modem, I get 120 mbps, when I connect via the Netgear router wirelessly, I get 60 mbps.
Remember wifi depends on the transmitter (router) and the receivers (wifi clients). 60 Mbps is the top speed that you will get for some wifi clients. You don't say what clients you are using.
What is the modem?
What is the firmware version on the router?
grahamfa
May 20, 2018Aspirant
HI,
- michaelkenwardMay 20, 2018Guru - Experienced User
grahamfa wrote:
HI,
- wcalifas831May 20, 2018Prodigy
For the range all I can advice is to set up the router in a central location of your property. For the speed, the 5.0 ghz you must the set the password security to WPA2-AES TKIP, and also the same for the 2.4ghz to reach the fastest speed on your router's ability.
- grahamfaMay 20, 2018Aspirant
Already confirmed this was set WPA2-AES TKIP
And there is no other place for connecting the modem/router but at the far end of the house
I did do a factory reset after updating the firmware.
And I'm aware of the differences between 2.4 GHz and 5. I was testing the range with the 2.4 GHz connection.
And testing both for the speed.I will see if I can return it.
- grahamfaMay 28, 2018Aspirant
I was able to return the router. I purchased a different brand of wireless router which is working great - great speed and reaches the end of the house. I appreciate the education on why the router I chose wasn't as good as described.
