rpgplayerrobin's avatar
Jan 14, 2021
Port Exhaustion
Hi!
I am hosting a server that clients can connect to using UDP packets.
The problem is that when using my router, only less than 4095 clients can be connected at a time, like some sort of port exhaustion.
When removing the router and connecting the modem directly to the computer, I can have around 16 700 clients connected (or more).
Setup:
Modem, HES-3109W2A(SM-10)-DR, with cable to ->
Router, NETGEAR WNR2200, Firmware Version V1.0.1.102, with cable to ->
Computer, Windows 10 Home 64-bit
My internet connection is 100/100 Mbps (I have also tried using speedtest).
What is it that is limiting the amount of clients connected so heavily when using the router?
No RepliesBe the first to reply
