jtvrls
Nov 25, 2020Aspirant
Port forwarding aircard 810s not working
Hi there, The port forwarding functionality does NOT work on the Aircard 810s. I have enable port forwarding and added varouis port. But stiil all of the added port remains closed when i nmap to...
antinode
Nov 25, 2020Guru
Or, it doesn't work the way you expect.
> I have enable port forwarding and added varouis port. [...]
Not a very detailed description of anything. What are your actual
port-forwarding rules? What are they supposed to do?
> [...] But stiil all of the added port remains closed when i nmap to
> the router on the local as the public IP.
The router's LAN IP address is different from its WAN/Internet IP
address. I would not expect port forwarding to be effective when you
specify the router's LAN IP address.
> The only 2 ports that are open are, port 80 (DMZ enabled) and 53.
Those would be the router's management web site, and its DNS server,
respectively. Looks normal to me.
> So there's defenetly someting worg with the firmwire. [...]
Not really.
> [...] I need a fast fix!
_You_ might, but there's no evidence here that the router firmware
does.
What's the IP address of the router's WAN/Internet interface? Have
you tried testing that?
For the usual problems with port forwarding, see:
https://community.netgear.com/t5/x/x/m-p/1859106
(That posting does not include talking to the wrong side of the router,
but, if you have other problems, you might find it helpful.)
