AEJ's avatar
AEJ
Follower
Dec 03, 2020
Port forwarding does not work properly, getting a ERR_CONNECTION_TIMED_OUT
Port forwarding worked fine on my older Netgear router I have at my regular residence but now I am working from my childhood home and, although I did the exact same thing to port forward on the router there (set up port forwarding at Advanced Setup > Port Forwarding / Port Triggering) I am getting a "ERR_CONNECTION_TIMED_OUT" message. I can get to the local LAN server (http://192.168.1.13/) fine and trying to go to a port I have not opened results in "ERR_CONNECTION_REFUSED" so it is is probably a firewall issue or a bug. I have tried authorizing port 80, 443, 2377, 4789, 7946, and port 1880 to no success. I have also restarted the router several times to no affect. I came across a few other people with similar issues in my search for an answer but have not found a good response.
This has eaten up way too much work time!
My router is a R6400v2, not a R6400v1
  • > My router is a R6400v2, [...]
       Firmware version?  Connected to what?
    > [...] my older Netgear router [...]
       Not a very detailed description of that device or its configuration.
    > [...] although I did the exact same thing [...]
       It's nice that you're happy, but, with my weak psychic powers, I
    can't see what you did at either site.
    > [...] I am getting a "ERR_CONNECTION_TIMED_OUT" message. [...]
       When you do _what_, exactly?  From where?  As usual, showing actual
    actions (commands) with their actual results (error messages, LED
    indicators, ...) can be more helpful than vague descriptions or
    interpretations.
    > [...] I can get to the local LAN server (http://192.168.1.13/) fine
    > bug. [...]
       You're doing that from a system on your LAN?  So, we're talking about
    some web server or other?  Running on a system of some type at
    "192.168.1.13"?
    > [...] I have tried authorizing port 80, 443, 2377, 4789, 7946, and
    > port 1880 to no success. [...]
       Exhibiting the actual port-forwarding rules might be helpful.
       And you thought that providing a sloppy problem description would
    spread the joy more evenly?
       For the usual problems with port forwarding, see:
          https://community.netgear.com/t5/x/x/m-p/1859106
       "1" is popular.  You seem to have covered "3".
    • antinode's avatar
      antinode
      Guru
      > [...] You seem to have covered "3".
         The first part, at least.  But I don't recall seeing any complaints
      about NAT loopback on the R6400v2, so I wouldn't expect problems with
      that.
