EconomyAC
Dec 21, 2022Follower
Port Forwarding Issues to Machine
RBR50 V2.7.34.24
2 Devices port forwarding to one is an NVR one is a Machine.
Wan IP is Static
The NVR ports works fine the machine ports do not.
Port works locally. I can VPN into to router and works fine as well.
Tried many different ports. I need 4911 and 5011 and for a web page I have tried 444, 448, 449, 80444, and several others.
I have done many netgear forwards first time with an issue.
local machine 192.168.1.160 reserved as static.
Protocol TCP assorted ports
I thought the machine may be an issue however the port works locally.
The Log shows lan access from remote port.
No RepliesBe the first to reply
