batchat25t_105m
Jul 07, 2017Follower
port forwarding missing fields?
so am trying to open ports for world of tanks and am using https://portforward.com/netgear/r6400/ as a source. now it asks me to fill these two fields External Starting Port External Ending Port ...
- Jul 12, 2017
Hi batchat25t_105m,
You can uncheck the option that states Use the same port range for Internal port. The link below may also help out.
Dexter
Community Team
DexterJB
Jul 12, 2017NETGEAR Moderator
Hi batchat25t_105m,
Dexter
Community Team
- DexterJBJul 17, 2017NETGEAR Moderator
Hi batchat25t_105m,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
