AaronM-Florida
Sep 08, 2020Follower
Port Forwarding not Disabling on R6250 Router
We are using a Netgear R6250 router at the office. I had enabled the port-forwarding feature to try to let the boss access the DVR from home. The port forwarding pointed to the DVR's local address of...
antinode
Sep 08, 2020Guru
> We are using a Netgear R6250 router [...]
R6250[v1] or R6250v2? Look for "Model" on the product label.
Firmware version? Connected to what?
> [...] the DVR [...]
Not a very detailed description of that device.
> [...] The port forwarding pointed to the DVR's local address of
> 192.168.1.200.
What was the actual port-forwarding rule? (I might guess external
port 80 to internal port 80, but that'd be only a guess.)
> [...] If I use IE, and input our external IP address, it prompts to
> download/install the "dvr_ocx.cab" file.
Are you running that test from a system on your LAN, or from a system
in the outside world?
> [...] the company verifying our network can see that DVR and file
> download request.
That suggests that it's (at least) a from-outside-world problem.
Is there a DMZ server specified on the R6250? (ADVANCED > Setup >
WAN Setup : Default DMZ Server) Any port-triggering rules defined?
UPnP? (ADVANCED > Advanced Setup > UPnP)
> Why is the port forwarding still pointing to the DVR when it was
> deleted?
Defective firmware would be one possible explanation. If the
port-forwarding rule list is empty, but the router is still doing port
forwarding (and there is no DMZ server specified, and there are no
port-triggering rules, and UPnP is disabled), then a settings reset (and
manual reconfiguration) might be the only reliable remedy.
A potentially interesting experiment would be to recreate the original
port-forwarding rule, but specify a target server address which is not
in use. (Reserve one for a fictional MAC address if necessary?) I'd
expect that to provide a work-around, but it shouldn't be needed.
