Lonewolf41
Feb 20, 2016Aspirant
Port Forwarding not working on WNR2000
I have a WNR2000v3 router with V1.1.2.12 firmware. I have 2 ports set to port forward, but when I try to access those ports, they are still closed. i have tried canyouseeme.org and tried from exter...
- Feb 24, 2016I figured out what is wrong. My provider is using CGN which is preventing me from using port forwarding since they scramble the ports on their end. Thanks.
ElaineM
Feb 22, 2016NETGEAR Employee Retired
Hi Lonewolf41 Did you factory reset your unit after firmware upgrade? If not, kindly push the reset button for 10 seconds and then reconfigure.
By the way, what ports did you forward?
Lonewolf41
Feb 24, 2016Aspirant
- ElaineMFeb 24, 2016NETGEAR Employee Retired
Thank you for updating us.
Have a great day!
