karatekidhero's avatar
Dec 20, 2016
Port forwarding not working R7000
Hello.
So I just got a R7000, mainly for better wifi and a better port forwarding experience. The wifi works great but haven't had any luck with the port forwarding. It just doesn't work allthough I set it up. I would say I have a decent experience with it too, as I did get it to work on my old Cisco router.
My setup works like this: I use the stock Cisco router connected to the modem with a coaxial cable. From the cisco I use a lan cable into the R7000.
Any help at all would be appreciated, as I am very dependent on being able to open ports for hosting servers.
  • The Cisco router is still in place?
    If so, you are double-routing. You need to change the forwarding rules in the Cisco, so that all the open ports are forwarded to the R7000 WAN port.  Then re-forward them from the R7000 to the appropriate WAN port.
    If the Cisco router lets you put a device in the "DMZ" you can also try put the R7000 in the DMZ, and remove all forwarding rules in the Cisco router.
    A third option is to set up the R7000 in AP mode, and use it only for WiFi.
  • StephenB's avatar
    • karatekidhero's avatar
      karatekidhero
      The Cisco router is still in place, yes.
      I am trying to put the router into DMZ but I need to find out what the R7000's IP adress is. How do I do that?
      Thanks!
