Blaksmith
Mar 23, 2020Aspirant
Port Forwarding of mixed ports does not work
I am having a port forwarding issue with this router. I used to use a Pf Sense full blown BSD machine, but since the motherboard died in it, I had to get something up and running fast, and grabbed t...
- Mar 23, 2020
Thank you again for your initial reply. I'm going to mark this as solved.
The issue was not the router at all. After further digging into the unit it is trying to connect to, the gateway was mis-configured.
Again, thank you for taking your time to reply.
antinode
Mar 23, 2020Guru
> [...] can be reached by using internal IPs directly, on their
> respective ports of 22 and 80.
Should also work (from a system on your LAN) if you specify the
router's WAN/Internet IP addesss and the appropriate external port
number (verifying NAT loopback).
> Has anyone else had issues like this on using mixed external /
> internal ports not working? [...]
Not I, but I don't have an R6220. I don't recall seeing any similar
reports about any model. (Some older models didn't allow setting
different int/ext ports, but that's a different question/defect.)
> Firmware: V1.1.0.86_1.0.1
Try something different/older?
> [...] grabbed this router. [...]
New, off a store shelf (or equivalent)?
Exercise the 90-day free support offer? Or the warranty?
- BlaksmithMar 23, 2020Aspirant
>> respective ports of 22 and 80.>
>number (verifying NAT loopback).I agree that it should but does not.
I honestly do not have the time to arbitrarilly pick an older firimware revision to test, and if it doesn't work, keep walking backwards.
>New, off a store shelf (or equivalent)?>
The router is over 90 days from the date of purchase. Again, I can not afford much down time with this issue, since I work remotely. With this virus going around, I can't just easily go grab antother one off the shelf, or wait a week or two for a replacement.
On a side note though, while waiting for a reply, I do have another router exactly identical, that is on it's own network, and uplink etc.. (not related to this network) and it does have the mixed port forwarding, which does work, so I'm stumped on this one. I just got done going through every single setting between the two of them, and everything is identical in regards to NAT / WAN / LAN setups. Just different IPs on that network, and their respective port forwrds. The other router that does work, is the exact same model, and firmware revision.
- antinodeMar 23, 2020Guru
> The issue was not the router at all. [...]
Thanks for the update. Considering the low incidence of similar
complaints (yours plus no others?), user error seemed likely.
