Blaksmith's avatar
Blaksmith
Port Forwarding of mixed ports does not work
I am having a port forwarding issue with this router.  I used to use a Pf Sense full blown BSD machine, but since the motherboard died in it, I had to get something up and running fast, and grabbed t...
  • Blaksmith's avatar
    Blaksmith
    Mar 23, 2020
    Thank you again for your initial reply.  I'm going to mark this as solved.
    The issue was not the router at all.  After further digging into the unit it is trying to connect to, the gateway was mis-configured.
    Again, thank you for taking your time to reply.
