Averaipod's avatar
Averaipod
Follower
Jan 03, 2021
Port forwarding on Orbi not working
Hello! I have been having issues portwarding on my Orbi and nothing seems to work. I have an at&t modem (which is not acting as a router) connected to my Orbi. I have done port forwarding on port 25565 on both udp/tcp on both the at&t modem and the orbi router. I have also disabled upnp and the orbi is on router mode. I use a port forward checker and it shows it is closed, any suggestions?
1 Reply
  • > [...] I have an at&t modem [...]
       Maker?  Model number?
    > [...] (which is not acting as a router) [...]
       Says who?  (Hint: Disabling the wireless-network radios on a wireless
    router does not stop it from being a router.)
    > [...] connected to my Orbi. [...]
       Model number?  Firmware version?
    > [...] the orbi is on router mode. [...]
       Ok.
    > [...] I have done port forwarding on port 25565 on both udp/tcp on
    > both the at&t modem and the orbi router. [...]
       If you're configuring port forwarding on your "the at&t modem", then
    it's not a simple modem.  Port forwarding is a router function, not a
    modem function.
       For the usual problems with port forwarding, see:
          https://community.netgear.com/t5/x/x/m-p/1859106
    I'd guess "1", because your "modem" is actually a modem+router.
