Bashir639
Feb 27, 2020Aspirant
Port forwarding on WNDR 4500
Im using a WNDR4500. Im not sure which version, but Netgear genei doesnt say if its any particular one so I assumed it was the first one. Im trying to host a server from my computer that my friends...
- Feb 28, 2020
Ok I figured it out! When you mentioned a NAT Router blocking my port I did some researsh to understand what you meant. To put it in layman terms for people like me, it means that the motem box is blocking your router from connecting to the outside world. I connected to my motems network and when into its settings (Im using Windstream) and I disabled all the firewalls. The I made a new port. I took the internal IP that was belonging to my router: 192.168.254.64 and ported port 25565 using TCP/UDP. Then the port checker was displaying my port was open and my firends were able to join my server. Thank you for the kind help, and I'm sorry if I gave you any hard times!!!
Bashir639
I noticed that my image didnt upload well so heres a list of the port settings:
Service Name: Minecraft Server
Service Type: TCP/UDP
External Starting Port: 25565
External Ending Port: 25565
Use the same port range for internal port: checked
Internal Starting Port: 25565
Internal Ending Port: 25565
Internal IP address: 192.168.1.26 (This si the IPV4 address of the laptop thats running the server)
antinode
Feb 27, 2020Guru
> Im using a WNDR4500. [...]
Connected to what? Some kind of modem or other?
> [...] every tutorial I could find on protforawarding. [...]
The non-psychics in your audience may have little idea what you could
find (or where you looked).
> [...] when I go to a Open port checker and enter my external ip:
> 75.89.xxx.xxx, it says my port isnt opened. I then tried entering my
> private ip: 192.168.1.26 and that still showed no results. [...]
Which "a Open port checker"? To any outside-world system, an
(unroutable, private) address like 192.168.1.26 would be unreachable.
"75.89.xxx.xxx" is a public address, but see item 1, below.
The usual problems with this stuff are:
1. Wrong external IP address (different from the port-forwarding
router's WAN/Internet IP address). (An intermediate NAT router, for
example, could cause this. Or an ISP using carrier-grade NAT to
conserve IPv4 addresses.)
Does the IP address of the WAN/Internet interface of your router
match what you're using as your public IP address from the outside
world? ADVANCED > ADVANCED Home : Internet Port : Internet IP Address
2. Bad port-forwarding rule (wrong port(s), wrong target address --
including a wandering target).
Yours looks reasonable.
How did you ensure that your game server system always has the right
IP address? Static configuration? Reserved dynamic address?
3. Server not listening on the port-forwarding target system.
Can you access the server from a system on your LAN using the
server's LAN IP address? If you can't access the server locally, then
there may be little chance of doing it from the outside world.
If that works, then, still from a system on your LAN, try using the
router's WAN/Internet IP address. That should verify the
port-forwarding rule(s) (and the "NAT loopback" feature of the router).
4. External influences: ISP blocking, other firewalls, ...
Seldom the problem.
- Bashir639Feb 27, 2020Aspirant
The router is connected to a motem that I got from Windstream, im not sure what model it is though.
find (or where you looked).I followed multiple tutorials on how to port forward for the game (Minecraft) on youtube, then I went to Reddit, then I went here. I followed around 5 or 6 forums on this website but I couldnt find anything.
I was using https://www.portchecktool.com/ and https://www.yougetsignal.com/tools/open-ports/ which both say the port is closed.
conserve IPv4 addresses.)Im not sure how to check if im using the wrong external IP address. I dont have an intemediate NAT router, and I'm not sure how to check if my ISP is ussing a NAT to conserver IPV4 addresses and im not sure what that means either.
world? ADVANCED > ADVANCED Home : Internet Port : Internet IP AddressWhen I go to advanced home I find the ip: 192.168.254.64. I thought my public ip adress was the 75.89.xxx.xxx number, so if thats so, then they are not the same. But I beleive I'm mixing something up here.
IP address? Static configuration? Reserved dynamic address?Im currently just trying to get the server to connect to others. I planned on making the IP static after I got the port opened, but if its a big deal I can try to make it static.
there may be little chance of doing it from the outside world.Yes I can access the server on LAN with the servers LAN ip address. I can also access it with the ip address found in the advanced home menu you mentioned earlier.
When I use https://www.portchecktool.com/ it says that the website cant connect with the port dure to the conncetion timing out rather than prompting it was refused by a potential firewall or ISP block.
- antinodeFeb 27, 2020Guru
> sure what model it is though.https://en.wikipedia.org/wiki/Modem
If it's only a modem, then it doesn't matter. If it's a
modem+router, then it could be a problem. With my weak psychic powers,
"im not sure what model it is" doesn't provide much useful information.Does it have multiple LAN Ethernet ports (as a router would)?
> I followed multiple tutorials [...]
That's all very nice, but if I wanted to look at any of that stuff,
how would you suggest that I find it? There are many "tutorials" "on
youtube", "Reddit", and elsewhere, and my life is short. There's also
the WNDR4500 User Manual.Visit http://netgear.com/support , put in your model number,
and look for Documentation. Get the User Manual. Look for topics like
"Port Forwarding and Triggering" (and "Address Reservation").> [...] I'm not sure how to check if my ISP is ussing a NAT to conserver
> IPV4 addresses and im not sure what that means either.If the two IP addresses don't match, then you've found the problem.
If your (unspecified) "a motem" is really a modem+router, then it could
be causing the problem. If it's not, then your ISP could be causing the
problem.https://en.wikipedia.org/wiki/Carrier-grade_NAT
> are not the same. But I beleive I'm mixing something up here.You've found the problem, but without some actual information on your
(unspecified) "a motem", it's tough to say who's causing it.> [...] I can also access it with the ip address found in the advanced
> home menu you mentioned earlier.Then you've done the port forwarding done well enough to make it
work, except for the extra NAT router (wherever it is).
If your (unspecified) "a motem" is really a simple modem, then the
only solutions I know are: 1) to ask your ISP for a real public address
(for which they might charge more), or 2) to use a tunneling service
like the one mentioned in another thread (near the end):https://community.netgear.com/t5/x/x/m-p/1748431
Some ISPs do not permit servers for residential customers, but I'm sure
that they'll tell you that if you ask.> Im currently just trying to get the server to connect to others. I
"Static" means configured on the device itself. "Reserved dynamic"
is configured on the router (DHCP server: ADVANCED > Setup > LAN Setup :
Address Reservation). Either should do the job, but "reserved dynamic"
might be easier to manage.But first you need to make it possible for an outside-world system to
get to your router. Locating the extra NAT router would be a good
start.- Bashir639Feb 28, 2020Aspirant
