Matt9378
Sep 05, 2015Aspirant
Port forwarding wont save
Hi, I have a WNDR4300 and i want to port forward various ports. A while ago i forwarded port 80 and that worked fine, but now if i want to port forward any other port it dosn't work. i click add cust...
- Sep 09, 2015
So, your post 8, after changing firmware did you factory reset the router, using the small pin-hole reset button?
ElaineM
Sep 08, 2015NETGEAR Employee Retired
Hi Matt9378,
Welcome to the community!
Sounds like it might be a corrupted firmware. Have you tried resetting the router for 10 seconds? If not please do so and see if it helps.
If the same thing happens, I suggest that you reflash the firmware of the router. Download the latest firmware on the website and upload it.
See this link on how to do firmware upgrade.
Let us know what happens.
Matt9378
Sep 08, 2015Aspirant
I have many times reset the router for over 10s but to no avail.
I'll try the firmware flash now and report back if it works or not.
Thanks.
