Matt9378
Sep 05, 2015Aspirant
Port forwarding wont save
Hi, I have a WNDR4300 and i want to port forward various ports. A while ago i forwarded port 80 and that worked fine, but now if i want to port forward any other port it dosn't work. i click add cust...
- Sep 09, 2015
So, your post 8, after changing firmware did you factory reset the router, using the small pin-hole reset button?
Matt9378
Sep 09, 2015Aspirant
Tried 3 different comps 2 ethernet 1 wifi and i have tried opera(no plugins) firefox(no plugins) chrome(no plugins) chrome(plugins) and all of them have the same result! getting a bit frustrated.
Thanks.
Babylon5
Sep 09, 2015NETGEAR Employee Retired
- Matt9378Sep 09, 2015Aspirant
No I havn't tried that. I will but im gonna do it later.
- Matt9378Sep 16, 2015Aspirant
Yep! :) I just reset the router by holding the little red button down and then manualy put in the wan settings and boom it worked!
THX!
- Babylon5Sep 17, 2015NETGEAR Employee Retired
Well that’s good. In that case when you are fully happy with your settings I suggest that you save the router configuration to a backup file, then in future if the issue re-appears you could try another factory reset and restore from that backup.
