LofferBoy
Aug 13, 2021Follower
port forwarding
 What services i need to run befor port forwarding?  please help me  My ISP supports port forwarding and the router as well but still  i am not able to reach my pc over the internet.  I have already e...
antinode
Aug 13, 2021Guru
I don't know what that means. What, exactly, are you trying to do?
> please help me
You first? What, exactly, are you trying to do?
> [...] i am not able to reach my pc over the internet.
"reach" _how_?
   "not able" is not a useful problem description.  It does not say
what you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> I have already enabled the "respond to ping on internet port"
> and "Remote Management".
   Unrelated to "reach my pc".
   Are you running a web server (on your "my pc")?  There's no reason to
hide that IP address.  (What about port 443?)
For the usual problems with port forwarding, see:
