carcanox32
May 31, 2022Aspirant
Port Fowarding r6120
hello i can't seem to open port with my router i was working well before i move out of my old place my router is connected to a modem. Here what i try so far is: i open a port through my router th...
carcanox32
Jun 02, 2022Aspirant
anyone ?
Jun 02, 2022Guru - Experienced User
What modem/gateway is your router connected to?
- carcanox32Jun 02, 2022Aspirant
there is no modem. i dont see one, my router is connected to a little box outside and then on the antenna on the roof
- plemansJun 02, 2022Guru - Experienced User
broadcast internet.
we always run into issues with broadcast internet. Not sure if its because they're operator side nat/routing or what.
i did call my operator and he said that is was not it fault the problem was not by him!
- michaelkenwardJun 03, 2022Guru - Experienced User
Which ISP is at the other end of this box?
You could try a search here for it.
As plemans says, "broadcast internet" isn't common. So there isn't much collective wisdom here on the subject.
