carcanox32
May 31, 2022Aspirant
Port Fowarding r6120
hello i can't seem to open port with my router i was working well before i move out of my old place my router is connected to a modem. Here what i try so far is: i open a port through my router th...
Jun 02, 2022Guru - Experienced User
What modem/gateway is your router connected to?
carcanox32
Jun 02, 2022Aspirant
there is no modem. i dont see one, my router is connected to a little box outside and then on the antenna on the roof
- plemansJun 02, 2022Guru - Experienced User
broadcast internet.
we always run into issues with broadcast internet. Not sure if its because they're operator side nat/routing or what.
- carcanox32Jun 02, 2022Aspirant
i did call my operator and he said that is was not it fault the problem was not by him!
- plemansJun 03, 2022Guru - Experienced User
I'm sure they did say that. What I'm saying is we see issues with things like this along using broadcast internet. Not sure if its because they use their own routing/nat/filtering or what. I haven't found a good answer for it yet.
- michaelkenwardJun 03, 2022Guru - Experienced User
Which ISP is at the other end of this box?
You could try a search here for it.
As plemans says, "broadcast internet" isn't common. So there isn't much collective wisdom here on the subject.
