Tobias6483
Feb 26, 2021Aspirant
Portforward (router + unknown device modem?? or)
Hello :) So i've just moved house, and I want to portforward. I tried portforwarding at my default gateway (192.168.1.1 - R6250 router) But when I go to canyouseeme.org it shows that the port is cl...
antinode
Feb 27, 2021Guru
> I live in a home with couple of floors
This tells me what, exactly?
> "Internet port" has a options in the gateway to portforward aswell as
> the r6260 netgear
Are you trying to say that your "home" has some sort of (unspecified)
"the gateway", and that you're connecting your R6250 to that "the
gateway"? "gateway" normally means "modem+router". That would make two
routers.
> Most likely, you should be using one router, not two. [...]
Still true.
> Im used to just login to 192.168.1.1 and portforward - and boom it
> works.
That's fine when your router is the only router.
> it says that the "internet port" in advanced home is the ethernet
> router..
It's an address on the LAN subnet of that "the gateway". I saw that.
> [...] i have ethernet into my pc not wifi
Doesn't matter. A network connection is a network connection.
> But I dont know what to do, to make my portforward work. [...]
Still true.
> [...] Typical one-router schemes involve either a modem-only and a
> router, [...]
I assume that other people are using that "the gateway" as their
router, so that scheme is not an option.
> [...] or else a modem+router and a wireless access point. [...]
That would be the one remaining option.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Use the Router as a WiFi Access Point Only".
> [...] I tried portforward in the "internet port" gateway [...]
I can't see what you "tried". There were numbers in it, right?
> [...] - but its say something like "IP address of port forwarding rule
> 1 is not within IP range of any bridge in route"
Because it can do port-forwarding only to an IP address on its own
LAN. If you configure your R6250 as a WAP, then all your devices will
be on the LAN of that 'the "internet port" gateway', so that complaint
should disappear.
> And when i portforward in the default gateway 192.168.1.1 it says
> connection timed out when i check if the port is open
Same problem, same solution.
Note, however, that with the R6250-as-WAP, you will be sharing the
LAN with other users of that 'the "internet port" gateway'. It's not as
private as having your own router.
Tobias6483
Feb 27, 2021Aspirant
When I enabled WAP(Wireless acces point) in the r6260 it says something like "Bridge 1 dhcpd host 1 IP address is not in the same network as dhcpd address" in the "internet port gateway" when i try to portforward. I don't know if it did that before i enabled WAP.. I tried to disable the WAP, but it still says that.
- Tobias6483Feb 27, 2021Aspirant
The case, is that i want to portforward my VMWare Linux local adress and a port (4444).. Without WAP it says
"IP address of port forwarding rule 1 is not within IP range of any bridge in router"
With WAP it doesn't say that
but no matter what it says "Bridge 1 dhcpd host 1 IP address is not in the same network as dhcpd address"
Sorry im not good at this im just used to no problems because i dont have this form of network setup..
Should I just ignore "Bridge 1 dhcpd host 1 IP address is not in the same network as dhcpd address" and enable WAP again. And then portfortward through the "internet gateway". With my VMWare local pc ip adress and the poth (TCP/UDP)
- antinodeFeb 28, 2021Guru
> something like [...]_What_ says that? When you do _what_?
Are you talking about your still-unidentified 'the "internet port"
gateway'? How much do you think that any of the non-psychics here knows
about it.Find a maker and model number for that gizmo. Then find some
documentation for it. Read.Do you think that any of the non-psychics here can see what you're
doing with it, whatever it is?
