LeRigodon
Nov 18, 2021Follower
Power Adapter for WNDR3700 connector size
The required adapter is rated for 12 Volt 2.5 Amps. Does anyone know the connecter size? 3mm?
- Nov 18, 2021
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-generalI would check out places like Amazon or eBay.
Thank you
Nov 18, 2021Guru - Experienced User
Thank you
