lacuentadelui
Apr 14, 2021Aspirant
Power LED blinks random
HI, I had a R6300 for 7 years. For some time it began to happen that the rooter stops working and the power led is blinking. After disconnecting the rooter for a few minutes it starts working again....
antinode
Apr 14, 2021Guru
> If it were a firmware problem, it always happened, right?
Probably.
Test/swap the power adapter?
lacuentadelui
I have no other adapter to test with.
How can I test the power adapter?
- lacuentadeluiApr 20, 2021Aspirant
Hello, is it possible to know how much is the maximum amount of artifacts that the r6300v1 router supports? Can the problem of the issue happen to reach that figure?
- wcalifasApr 20, 2021Prodigy
I suggest trying a different power adapter if the power blinking led still has issues. If its not the power adapter maybe the capacitors in the router might be going out.
