markdorsey
Jun 05, 2021Aspirant
Power Outage, now no LAN...no Hard Wired Connections "Ethernet" doesn't have Valid IP Configuration
I had a power outage about 6 months ago, and was able to muddle my way through a reset, and was going along just fine with my wifi and hard wired connections. But, a couple of power 'blips' a week or...
michaelkenward
Jun 06, 2021Guru - Experienced User
markdorsey wrote:
This all worked, perfectly, up until the recent storms, and a couple of quick 1-2 second power 'blips'.
plemans has offered you some things to try. I chip in merely to warn that storms are very good at frying electronic gubbins. The bad news may be that your storms broke something permanently. I would test every single items on its own to confirm that it still works as a standalone device before joining it all up into a network. Check that any helpful LEDs are as they should be.
markdorsey
Jun 06, 2021Aspirant
That I can tell, all LED's are as has been for months, now. As stated, and is infuriating...this exact scenario plays out when storms blow through, and the power flickers. It happened months back, with this exact set up, and I was able to do what was just prescribed (have doen so like 5 times, now) and no change.
Thank you all.
