MObersh
Jan 18, 2021Aspirant
Powerline 1000 wifi connection with SmartThings
Purchased a Netgear Powerline 1000 v2 + WiFi adapter and connected it to my SmartThings Connect router. Trying to get WiFi in a building out back. All lights indicate green but unable to connect to th...
antinode
Jan 18, 2021Guru
> to my SmartThings Connect router. [...]
What, exactly, did you connect to what, exactly? (Hint: If a device
has different types of Ethernet ports, then "connected to device" is not
enough detail.)
Has your "SmartThings Connect router" a model number?
> [...] All lights indicate green but unable to connect to the _EXT
> network. [...]
Which "lights" are "All lights"? As I read the "PowerLINE 1000,
[...]" User Manual, the PLW models have a blue "WiFi LED". Is yours
green, or dark, or absent, or what?
> [...] unable to connect to the _EXT network. [...]
"connect" what? "unable" is not a useful problem description. It
does not say what you did. It does not say what happened when you did
it. As usual, showing actual actions (commands) with their actual
results (error messages, LED indicators, ...) can be more helpful than
vague descriptions or interpretations.
Does your (unspecified) wireless device detect an "_EXT" SSID? Are
you using the right passphrase for it?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for the LED
descriptions and "Troubleshoot".
> [...] Trying to get WiFi in a building out back. [...]
I'd do my basic set-up in one room, and, when everything works that
way, _then_ I'd start separating the various gizmos.
- MObershJan 19, 2021Aspirant
Thanks, to be more specific...
> to my SmartThings Connect router. [...]What, exactly, did you connect to what, exactly? (Hint: If a device
enough detail.)- Connected ethernet cable from Arris Surfboard modem to my Netgear PWL 1000 Adapter
- Model #ET-WV525BWEGUS
> network. [...]Which "lights" are "All lights"? As I read the "PowerLINE 1000,
green, or dark, or absent, or what?- On the main adapter: Power LED green, Ethernet LED green, Pick A Plug LED green. On the Wifi extension adapter: Power LED green, Ethernet LED green, Pick a Plug LED green, Wifi LED blue. See: https://www.downloads.netgear.com/files/GDC/PLW1000v2/PLW1000v2_QSG_EN.pdf for image of indicator lights.
vague descriptions or interpretations.- The NetgearXX_EXT network shows up (i.e., wifi signal is there). However, when connecting my smartphone or smart TV, each device will NOT connect to the network. On my smartphone, "weak security" warning pops up. TV and phone won't connect to the wifi network though. Using default password that came with the Netgear PWL product.
you using the right passphrase for it?- Yes, device picks up the _EXT SSID. Using the exact password that came with the product. Won't connect to the _EXT wifi network though.
descriptions and "Troubleshoot".- Been there, done that. Not helpful. Saw a youtube where a technician said that WPA settings / encryption might be an issue. Not sure I can change that on my Smartthings router though. Would be curious if anyone has done this.
way, _then_ I'd start separating the various gizmos.- Thanks, I tried to connect to the Netgear _EXT network in a room adjacent to my router/modem but that wouldn't even work. Still getting the same problem with connectin to the wifi network even though all of the "indicator lights" (as summarized above) tell me that the product is functioning.
- antinodeJan 19, 2021Guru
> 1000 AdapterThat sounds like a horrible plan.
Given a question like that, did you really believe that "Arris
Surfboard modem" would be a valuable description of that device?Assuming that "Arris Surfboard modem" really is a modem, then it
should be connected to the WAN/Internet port on some router, not to an
extender. At that point you were probably doomed.Did you look at the pictures in the documentation for these gizmos?
Were they ever shown on the WAN/Internet side of a router? If these
gizmos were strings of Christmas-tree lights, then you might be able to
string them together in any order you might wish. But they're not.
The extenders are used to extend your LAN; connect them there.- MObershJan 19, 2021Aspirant
Believe me, I am admittedly very IT dumb. Looking for any help. Here's pictures of each of the connections to each of my 3 products (Arris Surfboard SB8200 DOCSIS 3.1 Cable Modem, SmartThings Connector WiFi Router, and the Netgear Powerline 1000 v2 + Wifi). Happy for you to tell me what to plug in where (or for you to tell me these things do NOT work together).
